Author Topic: Engine coolant top up  (Read 17582 times)
Re: Engine coolant top up
« Reply #15 on: January 13, 2017, 10:59:47 PM »
Check to make sure if you need FL22 or not.  See postings above
« Reply #16 on: January 13, 2017, 11:59:08 PM »
hi all  From the picture that's not fl22 as mines dark but clear green colour ,it looks more of a rusty water colour unless its the orange colour  long life coolant.
Offline amar1994
  • Zoom-Zoom
  • Trim: Tamura
« Reply #17 on: January 14, 2017, 12:40:09 PM »
Yes, it is not FL22 , it's G12 blend  ;)
Did I mention that I can't get a hold on FL22 , because , well I'm from Bosnia haha >:D
Don't scare me @speedy mazda  :P :D , it's not rust  :)
« Last Edit: January 14, 2017, 03:44:59 PM by amar1994 »
Offline amar1994
  • Zoom-Zoom
  • Trim: Tamura
« Reply #18 on: January 14, 2017, 03:47:06 PM »
Anyway , I toped it up today with little deionised water  :) , also checked freezing point and it's around -25 degrees celsius which is ok  :)
Offline amar1994
  • Zoom-Zoom
  • Trim: Tamura
« Reply #19 on: May 28, 2017, 10:24:04 PM »
So to add on this , I had a leak . Somebody forgot to tight one of the clamps on a hose , stupid authorized service/dealer was doing coolant change 2 years ago , I was lucky enough that hose didn't brake lose and cause massive leak and probably engine overheat . Also I inhaled good amounts of antifreeze vapors , oh well ****** happens LOL :P
Luckily i found good and honest mechanic , and above all else good friend and honest man , who spotted this and showed me the leak before fixing it.
To end this , here is one pic from servicing yesterday  :)
Best regards. ^-^
« Last Edit: May 28, 2017, 10:29:30 PM by amar1994 »
Offline phoibos
« Reply #20 on: December 18, 2017, 03:53:58 PM »
Sorry for digging this topic up :P  :D , but I don't want to start a new one and I am wondering , do I need to top up my coolant?
Here is an image "warm engine"  ;)
My coolant level is also very similar to the level in the picture. Today I've checked with my regular garage, they've checked the fluid with the tool. It was OK. They said no need to worry about slight miss of the min level line.
Regards,
Offline amar1994
  • Zoom-Zoom
  • Trim: Tamura
« Reply #21 on: January 04, 2018, 10:58:14 PM »
Regards,
Thanks for the info , now it's right between min/max , and everything runs fine , I had a small leak , one of the hose clips was lose .
