Author Topic: Rear door trim removal  (Read 9523 times)
Offline Mindis
« on: November 13, 2010, 07:07:52 PM »
Tools you will need:
*phillips screwdriver
*flat screwdriver
*upholstery removal tool
Approximate time: 5min
Steps:
1. Remove plastic covers and screws
2. Detach clips from the door using upholstery removal tool
3. Lift trim upwards
4. Disconnect power window connector
5. Install in the reverse order of removal
I got easy access to the door by removing loud speaker and removing foam covers.
Offline Wash
Re: Rear door trim removal
« Reply #1 on: February 22, 2013, 05:03:50 PM »
Just to add to this, for anyone's who wanting to remove the rear door cards but has a manual window winder (like on the TS models) then you need to grab a little piece of cloth (I used a sock lol), put it behind the window winder and move the cloth around so you can loosen off the little clip that holds it in place.
