Author Topic: Should door panels be this weak?  (Read 3583 times)
Offline Grangemouth
« on: January 29, 2010, 01:27:25 AM »
I'm not so pleased with my 3 as when I first got it.  True, it drives well (except on snow & ice!).  But the bodywork seems so flimsy.  The other day I was assisting a passenger with walking difficulties into the front seat.  For stability, I leaned my bum against the rear door and felt something give....the door, not me!  At the time, I assumed that the panel had just pressed in slightly and popped back out as soon as the pressure was taken off.
But when I checked it afterwards, I was horrified to see a permanent distortion of the door panel.  Not really a dent, but a distinct variation in the shape of the curved surface.  The horizontal fold about 200mm below the window has a kink in it, which I think is the reason the panel cannot recover its original shape; the metal has been slightly stretched.  I am disgusted to find that the metal is so thin and weak that it can be damaged just by leaning on it.  I only weigh 11 stone!
I don't suppose the warranty would cover this?  Presumably it would be counted as accidental damage!
Offline mazda3-mike
  • went 'somewhere back in time' with eddie the 'ed
    • pro wedding videographer..!
Re: Should door panels be this weak?
« Reply #1 on: January 30, 2010, 08:56:51 AM »
any pictures!
1979 Datsun160j Met Green
1996 Ford Escort 1.4GL Grey
1998 Rover 214 Red
2000 Rover 414 silver
2002 Toyota Corolla 'Pink'
2003 Nissan Almera 1.5s Sky Blue
2004 Mazda3 TS 1.4 Met Grey
2010 Mazda3 TS 1.6 Aluminium (current car)
Offline Grangemouth
« Reply #2 on: January 31, 2010, 10:59:57 PM »
any pictures!
I don't think it would show up in a photo, Mike.  As I said, it's a subtle change of curvature rather than a dent, but annoying nevertheless.  You see it when looking along the side of the car from the front or rear end, and the distorted reflection makes it more obvious.
