Author Topic: Drivers seat 2005 3 ts  (Read 3953 times)
Offline mazda3-mike
  • went 'somewhere back in time' with eddie the 'ed
    • pro wedding videographer..!
« on: January 05, 2010, 11:07:29 PM »
the adjuster handle (raise & lower seat adjuster) has jammed and the seat will not lower, any ideas how to reset the mechanism, i suspect the seat may have tobe removed?
1979 Datsun160j Met Green
1996 Ford Escort 1.4GL Grey
1998 Rover 214 Red
2000 Rover 414 silver
2002 Toyota Corolla 'Pink'
2003 Nissan Almera 1.5s Sky Blue
2004 Mazda3 TS 1.4 Met Grey
2010 Mazda3 TS 1.6 Aluminium (current car)
Offline Moorsey19833
Re: Drivers seat 2005 3 ts
« Reply #1 on: June 20, 2010, 10:06:49 AM »
Hi, Did you resolve this problem?
i have the same problem with my 2004 ts i just bought.
cheers
« Reply #2 on: June 21, 2010, 06:55:06 PM »
BUMP
Anyone know the answer to this?
Offline carlosnewry
« Reply #3 on: June 21, 2010, 08:31:48 PM »
would just holding the handle and trying to force it down get it moving??
get a 'large friend' to try and do it. lol usually works
« Reply #4 on: June 22, 2010, 06:29:33 PM »
the handle moves up and down slightly and seat moves a fraction, but can not get it to move past that?
Offline jackal
« Reply #5 on: June 29, 2010, 08:43:03 PM »
i've got the same problem on mine, i was sat that high i felt like a was driving a 4 x 4, i managed to move the seat down by pulling the handle away from the seat and then moving the lever up and down eventually the handle started to grip the mechanism, it doesn't always work but i stuck at it and now the seat is at the bottom position
Offline finchy
« Reply #6 on: February 11, 2014, 05:41:37 PM »
We had this same problem, I sort of solved it by figuring out how the mechanism works, it's a toothed cog, or gear, and each time the handle is operated up or down a little toothed key operates the cog and indexes it a fraction, up or down accordingly, the problem lies in that the key moves in and out to grip The cog and index it, it's actuated by a nylon finger that must wear, our seat got stuck at the uppermost position so I stuck my head under the seat with a torch and screwdriver and with the Mrs Sat on the seat returning the lever and me indexing the cog we got the seat back to the low position.
