Author Topic: Sound deadening  (Read 10084 times)
Offline Mindis
Sound deadening
« on: July 12, 2009, 06:27:19 PM »
Where is the best place to start sound deadening? boot? doors?
has anyone tried sound deadening? is it worth it?
Offline Mindis
Re: Sound deadening
« Reply #1 on: July 13, 2009, 05:00:34 PM »
Noone?  :(
Offline darrude
Re: Sound deadening
« Reply #2 on: July 13, 2009, 09:30:58 PM »
Depends what your trying to deaden.  In-front of the Bulk head and behind the IP then carpets i'd guess in terms of best benefit.
Offline MPS Power
Re: Sound deadening
« Reply #3 on: July 26, 2009, 07:39:48 PM »
If you want to crank the bass up with minimum vibration etc then dynamat etc on the inside of the doors can be useful.  Just remove the door cards first  :P
08 True Red MPS Aero
Offline sweeden
Re: Sound deadening
« Reply #4 on: January 17, 2010, 02:26:55 PM »
well as this is my first post me thinks you should be honoured....
if your trying to deaden the rattles/distortion form the speakers in the doors then you should deaden the door itself. to go on from this you should deaden the outer door skin. as i have never taken apart the 3's door here's how i have previously done it.
remove the window and slide one large piece into the door from above them gently using a decorators roller make sure the deadening gets 100% contact.
after this it all depends where your sound is rattling e.g. if you have a subwoofer in the boot then th whole of the boot would be a good idea to deaden.
if it is road noise you are trying to deaden then you can use 'envirolay' £15 for a massive sheet and you just put this everywhere; roof, doors, boot, floors i mean everywhere hope this helps
Offline Mindis
Re: Sound deadening
« Reply #5 on: January 17, 2010, 02:31:45 PM »
Welcome to the forum and cheers.
I was looking to deaden road noise, and I am not sure about door's.It looks to complicated for me   :P
Where I can get that 'envirolay'?
Offline sweeden
Re: Sound deadening
« Reply #6 on: January 17, 2010, 06:13:21 PM »
Re: Sound deadening
« Reply #7 on: January 17, 2010, 09:02:59 PM »
is there anything that can be applied to the back of the plastic wheel arches that will absorb the road noise??
Offline Duc de Pommfrit
  • Forum shopkeeper
Re: Sound deadening
« Reply #8 on: January 17, 2010, 09:08:46 PM »
How about something for the bonnet?  And where are I get it?
Offline sweeden
Re: Sound deadening
« Reply #9 on: January 17, 2010, 11:52:32 PM »
you could always try removing the wheel arch lining giving it a good clean and sticking the envirolay to the back using 'contact adhesive' NOT spray glue.
Offline sweeden
Re: Sound deadening
« Reply #10 on: January 17, 2010, 11:54:16 PM »
same again really, envirolay and contact adhesive.
envirolay will reduce road noise and stuff like dynamat will stop vibrations, or as the advert says 'sound like a golf'
Offline Mindis
Re: Sound deadening
« Reply #11 on: January 18, 2010, 12:22:37 AM »
Re: Sound deadening
