Author Topic: poss abs problem  (Read 2080 times)
Offline bri6172
poss abs problem
« on: January 27, 2020, 09:27:19 PM »
Hi I have a mazda 3 2014 with 3 malfunction city brake assist,traction control malfunction, tyre pressure monitoring malfunction I have had a diagnostics on the car witch is showing multipal communication errors they are going to have the car for further investigation but possibly suspect abs ECU at fault can anybody advise me if they've had the same issues tia
Re: poss abs problem
« Reply #1 on: January 27, 2020, 10:05:22 PM »
Did the garage tell you the fault codes? When my abs went wrong my code was c0020:1 c 68 pump motor control but it threw up steering angle sensor code too.The abs unit was sent away and it looked like they changed the motor not the ecu.Mazda had a lot of problems with abs motor brushes in USA I’ve read.Mazda wanted 1200 for a new abs unit not including labour. Got it reconditioned including labour for just over 500.
Offline bri6172
« Reply #2 on: January 28, 2020, 01:37:42 PM »
no he haven't said what codes but he said it was showing multiple codes and suspect the abs but when he has it in he is going to check inputs and outputs on the abs ecu
