Author Topic: ELECTRIC DOOR MIRROR  (Read 7016 times)
Offline EWT
« on: October 06, 2019, 06:08:15 PM »
Had the drivers door of our 2017 Mazda 3 Sport Nav resprayed to repair a scratch. The electric folding door mirror was removed for the respray and replaced afterward. When the car is stopped or started the drivers door mirror will not fold in or out when in the Auto position. I believe this mirror is irretrievably damaged. Does anyone know the part No for a new right side electric door  mirror (Less Glass and cap)?
Offline misar
  • Year: 2019
Re: ELECTRIC DOOR MIRROR
« Reply #1 on: October 06, 2019, 08:48:15 PM »
Does the mirror power in and out when operated manually with the push button? If so it seems unlikely to be a fault with the mirror. Auto operation or not it is still using the same motor and gearing.
Offline EWT
« Reply #2 on: October 08, 2019, 02:48:21 PM »
The motor works but only through a limited traverse.
« Last Edit: October 10, 2019, 07:46:50 PM by EWT »
Offline EWT
« Reply #3 on: October 10, 2019, 10:36:05 AM »
Oops! One mirror glass location spigots broken when investigating wing mirror fault.
Told by Mazda dealership that due to water ingress it is a common fault that wing mirrors "auto rotate" can fail and that it is difficult to detach wing mirror glass without breaking plastic location spigots on the rear of the glass.
Has anyone else experienced any of these two things?
Offline phiso
« Reply #4 on: November 18, 2019, 06:49:03 PM »
2016 Sport Nav
Not quite the same problem, but I get the usual sticking mirror issue where one of the mirrors refuses to fold in or out from time to time. It's important they fold for me or I can't get the car into the garage, and the problem is  normally sorted with a blast of WD40.
You see, I use the folded-in passenger mirror as my guide for the car being far enough over to the left so that I can get out of the car without doing myself an injury. Only this time I didn't check that the driver's side mirror had folded in... and it hadn't  :o  Crump!...and now the d/s mirror doesn't move at all in either direction (glass movement and indicators are all OK) and there's this constant whirring noise as the motor tries to move the mirror.
Mazda can fix it of course, hurrah! Or rather, they can replace it. At a cost. Just 324 of our finest British pounds, that's all  :(
Maybe I just need to remember that there are two mirrors, not one. Or perhaps Mazda should make mirrors that don't start sticking after only 2 or 3 years so that we mere drivers don't have to be so paranoid about what happens when they do! Grrrr!!!
Offline Ed-Led
  • Colour: Jet Black Mica (41W)
« Reply #5 on: November 18, 2019, 08:45:25 PM »
This is a known fault at Mazda, my partner's driver door mirror started sticking on her 2017 2.2d and she had to have it fixed on the warranty. I'm not 100% sure but it might be a recall issue as well. They basically owned up to admitting there's a lot of cars with this problem.
Ford Escort 1.6 Ghia WNF 541S 1991 to 1992
Ford Orion 1.4L F965 KRJ 1992 to 1998
Mazda 323f 1.8 Executive P299 GBA 1998 to 2005
Mazda 323f 2.0 V6 ZXI SE S878 JHN 2005 to 2006
Mazda 323f 2.0 Sport SY02 ECJ 2006 to 2013
Mazda 3 2.0 Sport I-Stop FD59 VVB 2013 to 2019
Mazda 3 2.0 Sport Nav 165 - 2019
Offline UraniumSnake
  • Year: 2018
« Reply #6 on: November 19, 2019, 08:11:34 AM »
I'm so glad this popped up. My D/S has started to fail occasionally when popping out. Thought someone had knocked it and broken it. Was going to suffer as I thought it would be a £300-400 fix.
Guess this will be warranty repaired along with the wiper motor recall  ;D
Offline Kentish
« Reply #7 on: February 09, 2020, 08:44:50 PM »
Ive just had the drivers side mirror motor replaced on my 2017 Sport Nav.
I'm told it's common across nearly all the model ranges right now, with a modified part being used.
« Reply #8 on: February 10, 2020, 01:25:19 PM »
Indeed - when my car was in a year ago for service, an owner of a gen-3 car had come in complaining about that very issue. Don't they check these things during the testing phase of R&D any more?  Are customers now the beta testers of car tech, just so they can get that tech to market first or to make sure they're not last out of the blocks?  So many 'little issues' (annoyances) on modern cars these days.
Offline Ed-Led
« Reply #9 on: February 10, 2020, 09:49:03 PM »
My partner's 2017 2.2d Sport has already had the motor replaced on the drivers side mirror. She's now going to need the passenger side doing as well due to the sticking issue. Both wing mirror motors (and a new DMF/clutch required) on a less than 3 year old car isn't the best really....disappointing.
