Author Topic: Note to new buyers of old 2's and 3's....beware underbody rust!!  (Read 4551 times)
Re: Note to new buyers of old 2's and 3's....beware underbody rust!!
« Reply #15 on: December 19, 2018, 09:16:01 AM »
interesting thread.
Thanks for the info Willpower.  ;)
Offline PJW17
« Reply #16 on: July 24, 2020, 02:43:31 PM »
My 11 reg Takuya has just been in overnight for a new oil sump - it had corroded to the point it would flake away when picked with a fingernail. Nightmare!
2011 Mazda 3 Takuya, Mica Black
Offline Solo_run
« Reply #17 on: July 28, 2020, 10:14:54 PM »
Are these sorts of problems occuring in anything post 2015?
« Reply #18 on: July 29, 2020, 08:15:29 AM »
They are too new to say, I've seen photos of gen 3 cars in Canada with pretty bad surface corrosion but they have terrible winter conditions.
Whether you need to worry will depend on your future plans for the car...basically if you plan to still have it long beyond 10 years old then I'd probably look into getting a long term rust treatment on the underside to prolong the life of the car.
If you're trading it in after 3 years..this doesn't concern you at all.
There's a luck of the draw element as well, gentleman above with a rotten sump for example, I have literally the same car my sump is fine despite the underside corrosion elsewhere. Will say mine was MOT'd last week and had no advisories for underbody corrosion at 9 years old, does have the issues I mentioned earlier in the thread but it is in general still solid and will remain so for a decent amount of time.
Is it perfect? No but it's 9 years old, and has done 84k miles as a daily hack so it was never going to be, looks tidy enough though.
« Last Edit: July 29, 2020, 05:23:42 PM by StevenRB45 »
« Reply #19 on: July 29, 2020, 03:33:30 PM »
Ditto for my gen-1 car, having passed it's latest MOT in early Jan 2020 yet again with no advisories on that score (only one for a windscreen non-issue) and (touch wood) no failures since new.  Location and usage certainly play a big part...plus a good dose of luck.  Mine, on the other hand, likes to go through batteries, now changed a fortnight ago to number 4 (once every 4-5 years) due to the low annual mileage.  Easier to deal with than significant rust though.
I do remember reports of rusting on early gen-3 cars only after 6 months of it being released, though mostly from North America.  Nothing since.  Most of the serious rusting issues appear (taking out living by the sea on in areas that have regular road salting in winter and high use) to be in the first 2-3 years of production of the gen-1 car before the mid-life makeover.  Maybe mine was lucky as it was produced about 5 months before that makeover.  One older (by a year) example near me is now starting to show serious signs of corrosion of the real wheel arches.  Another, slighly newer (by about a year as well) looks to be fine.
Offline Ed-Led
« Reply #20 on: July 29, 2020, 06:51:29 PM »
Early Noughties Mazdas were seemingly quite bad for rust. I had three Mazda 323's before moving onto a Mazda 3, the first two from the mid/late 90's didn't seem to corrode much but my last 323 from 2002 was bad. The rear wheel arches were going fairly early and by 10 years old the rot was terminal in the strut top mounts. Rusty rear wheel arches seemed to transfer over into the very early Gen 1 cars too.
 I've not had any rust issues on both Mazda 3's i've owned (Gen 2 and current Gen 3), my first one was 9 years old when i changed it out and there wasn't any rust on it that i could see, even the underneath was really good.  I'd guess Mazda have long since sorted out the sort of body rust on those last 323's but i think they still have issues with alloy wheel corrosion.
« Reply #21 on: July 29, 2020, 06:58:44 PM »
getting me worried now guys, I'll have to have a shimmy under the motor. :D
Offline Solo_run
« Reply #22 on: July 29, 2020, 08:17:55 PM »
I'm hoping I'll be alright as I don't live anywhere near the sea (Coventry). I guess there would be no harm in doing a bit of maintenance on the car from time to time and I suppose ensuring the car is service regularly helps to prevent any major issues.
« Reply #23 on: July 29, 2020, 11:20:11 PM »
To be blunt, I would hope that you would be doing that anyway. You are making a large investment. Looking after your car should be a no brainer.
Offline Solo_run
« Reply #24 on: July 30, 2020, 12:07:53 AM »
Definitely will be looking after it. It's going for its services and will have detailing done. I am likely to keep the car for minimum of 3 years and for the next three years I'll be looking at doing something like 63k miles in it (45 odd will be motorway) as I have bought it to get me to university. It already has 16k on it and it is 16 plate. I want it to have some resale value
« Reply #25 on: July 31, 2020, 04:55:43 PM »
Serious corrosion can happen if you live or regularly drive through areas that get bad (icy / snowy) weather in winter that results in the local council or Highways England salting the roads on a regular basis in winter.  If it is, then you'd probably need to clear it off, including the underside, far more often so that the caked on salty water doesn't start the corrosion or make it worsen (and more quickly).  Often can be a lot worse if you live in a rural area near to a major trunk road.  More so if you use the car a lot.
