Author Topic: Just got Mazda3 - can't figure out how to set the clock/time??!!!  (Read 1528 times)
Offline spacedmonkeys
  • Colour: Carbon Grey (28B) Metallic
Loving the car and the drive home from picking it up (Mazda 3, 2009, 2.2 diesel 185).
I usually rely on the car clock for arriving at work, see if I'm on time/late etc...
However I've read the manual, played with all the settings, and can't seem to set the time. Am I being incredibly thick/missing something obvious?
The only place I can see any sort of clock or time is in the top right of the built in satnav. There doesn't appear to be one on the radio display or on the actual dashboard?
The dashboard/centre console has a "H:M:12/24hr" set of buttons, which just beep if i press them or hold them down, they don't adjust any clock (that I can see).
Is there some other clock/time that I'm missing? Is the one in the satnav the only one?
And if so how do I set the time on it? it currently just displays "--:--".
I looked in the settings for the satnav, and there's a time zone setting. There's also a "automatic adjust time" option which is greyed out.
Re: Just got Mazda3 - can't figure out how to set the clock/time??!!!
« Reply #1 on: August 11, 2018, 06:17:36 PM »
On mine those buttons do it? I don't have Nav though. The screen to the right of the climate display has the clock on it.
On mine it's literally just a short press of the button = 1 minute or hour and holding cycles it.
On nav equipped cars it's apparently hidden in the settings/calibration.
« Reply #2 on: August 13, 2018, 08:44:06 AM »
Well, been messing about with this since Saturday and it seems like it just doesn't want to work.
The satnav screen is supposedly where the time is shown.
All it shows for me is "--:--"
According to the manual the time is not shown when no gps signal is being received. But the satnav itself is working fine so it must be getting gps.
No idea what's up with it but it's annoying.
Offline Alfisto
  • Body: Fastback
« Reply #3 on: August 13, 2018, 10:56:52 AM »
On mine, in the settings menu, the clock tab gives you two options. To set the time manually or to synchronise with the GPS. does yours?
« Reply #4 on: August 13, 2018, 11:37:01 AM »
hmm no option for "clock"..
This is the same system that is in mine:  https://www.youtube.com/watch?v=2K30ZsLhRbM
Offline Alfisto
  • Body: Fastback
« Reply #5 on: August 13, 2018, 12:52:15 PM »
No, not the same, sorry.
« Reply #6 on: August 21, 2018, 03:43:52 PM »
Actually, I think I figured it out, the satnav ISN'T getting a GPS signal. Despite it "tracking" where I am... (I think the software knows my location and uses the internal software rather than GPS position to work out where I'm moving).
So I guess next question I'll go searching for is how to replace/repair the GPS receiver.
Offline misar
« Reply #7 on: August 24, 2018, 09:55:22 PM »
I assume you have the Gen 2 car. I have had one since 2009 and can assure you that the dashboard/centre console  "H:M:12/24hr" set of buttons resets the clock. I have never found any other way so if there is a fault on your car it is there, not the GPS.
It is annoying to do a manual reset twice a year re summer time - on a GPS system that would be automatic.
For information this system is in some ways better than current ones because it uses GPS signals, a speed sensor and gyrosensor. So it will indeed keep an accurate position without GPS for a while (even after the car has been parked) but without GPS at some point the position will become increasingly inaccurate. For example the speed and distance measurements on a car will never be 100% accurate. If the position is spot on after a long trip it is highly likely that GPS is working correctly.
« Last Edit: August 24, 2018, 10:05:58 PM by misar »
« Reply #8 on: September 04, 2018, 10:16:59 AM »
Yes it is a gen2... 2.2 diesel sport... Pretty sure it is the GPS receiver that is not working... looks like prior to me obtaining the car someone did a "manual adjust location" onthe unit, and it appeared to be working... but having done a few long journeys it no longer has any idea of where I am.
Unless I am being completely daft, there is nowhere on the dash that shows the clock other than on the satnav unit.
I've uploaded some pics to flickr to show it.
https://flic.kr/s/aHskE5qZ8c
« Reply #9 on: September 04, 2018, 11:22:32 AM »
Have you tried looking for the correct manual for your car  ( By VIN Number )   on the Mazda website here   https://www.mazda.co.uk/buying-owning/product-features-and-manuals/#
« Reply #10 on: December 13, 2018, 02:21:49 PM »
I take it nobody else has had this issue hence the lack of replies in months.
Looks like a trip to a dealer then.
As for checking the manual, yes first thing i did (after trying to figure it myself for far too long).
Only thing the manual states is that the time will not be displayed if the GPS is not receiving signal, which is probably the issue, but I can't find any clues as to where the GPS receiver is, how to check it, reset it, etc etc.
