Author Topic: Front Sidelight bulb replacement  (Read 1183 times)
Offline AbbCon
« on: June 11, 2018, 09:00:24 AM »
Morning All,
My 53 plate, Mazda 3 TS2 has just failed its MOT on a suspension joint and front sidelight bulb.
The suspension joint is not a problem, but i have read on Mazda Technical Manual you need to remove the front bumper to change the OS sidelight bulb. Is that true, and is there a shortcut? I can remove the bumper with no problem, but I can never realign them properly when refitting.
Any help will be much appreciated.
Regards
Kenny
Re: Front Sidelight bulb replacement
« Reply #1 on: June 11, 2018, 10:59:54 AM »
No need to remove anything other than the bulb holder. It's fiddly especially if you've got big hands. From memory, the lamp holder requires about a quarter turn anticlockwise, then it should pull straight back.
