Author Topic: Replacing battery in key?  (Read 1927 times)
Offline john10001
« on: November 12, 2017, 06:54:01 PM »
How do I replace the battery in my keys? I have Mazda 3 1.6 TS (2009).
The keys are oblong and the key folds into the plastic.
How do you open these things and what battery do they take?
Cheers!
Re: Replacing battery in key?
« Reply #1 on: November 12, 2017, 07:35:20 PM »
Flip the blade out, you should be able to see a small plastic square tab. You cab press this with a small screw driver. That allows you to remove the blade. Now thats gone you'll see an indentation on the button side. Again use a small screw driver to gently prize apart. You should now be able to see circuit board and battery. Battery is a CR1620.
