Author Topic: Finally fixed my rattle/Broken rear coil spring  (Read 2462 times)
Offline marcddsa
  • I guess I should update my signature strip!!!
  • Engine: 1.4L
  • Trim: S
« on: October 03, 2017, 10:14:20 PM »
For a while now (actually since I got the car a year ago) I've had an annoying rattle coming from the right rear when going over bumps and I FINALLY got around to checking it out and found it was that undocumented feature of breaking rear coil springs....  ;D
Took the wheel off and got out my trusty rubber mallet and went a-beating around all brake and suspension bits and found the culprit.. About 3 inches of the lower part broken off..
I've seen a few of these issues on this forum and on a lot of the US forums as well so it might just be a feature :-)
Seems to be an old break though looking at the corrosion on the break - strange it wasn't picked up at the last NCT (MOT to my mates over the sea) 3 weeks ago...
Will do the replacement when the parts arrive - seems like a simple enough job with the right tools...  :) :)
Offline audioslaven
Re: Finally fixed my rattle/Broken rear coil spring
« Reply #1 on: October 03, 2017, 11:19:54 PM »
This is funny as I did mine a week ago. You need to remove the drop link and one bolt holding where the axle meets the wheel rim. I used an air gun to wip it off. I put the car up on axle stands and the trolley jack to push the new spring back in place when fitting it back. Very straight forward job
Offline marcddsa
  • Engine: 1.4L
  • Trim: S
« Reply #2 on: October 04, 2017, 08:45:07 AM »
Thanks for the info  :D
Seems easy enough to do. Will let you know when it's done...
