Author Topic: Fuel Bleeding/Priming  (Read 1202 times)
Offline zale
« on: April 28, 2017, 06:20:13 PM »
Hi Guys,
 I replaced the intake manifold which had a crack in it. To do this I had to remove the metal high pressure lines and electrics. I replaced everything and left the high pressure lines cracked a little thinking when I turned over the engine it would bleed the lines for me with a little squirt of diesel and bubbles.
Nothing happened so I fully opened one line and turned it over. There's no fuel at all coming. The car was sitting there for a few weeks.
Question is : How do I prime the system and will I need to buy a manual pump or is there one hiding on me in the engine bay somewhere lol.
Photo won't upload. I try later.
Offline paulm94
Re: Fuel Bleeding/Priming
« Reply #1 on: January 19, 2018, 10:54:35 PM »
Not sure if im too late but on 2.2 ther is a little blanked off pipe with a clip on it where you can suck diesel through and starts first time o.der models had primer on top of fuel filter near battery near back of bulk head
