Author Topic: How to install a reversing camera 2014 Sport Nav Fastback  (Read 25241 times)
Offline NickG
  • Colour: Titanium Flash Metallic (42S)
Re: How to install a reversing camera 2014 Sport Nav Fastback
« Reply #15 on: April 23, 2017, 12:50:24 PM »
Thanks for all the advice! I just installed a camera in a 2014 Hatchback using Whrrr's instructions above.
I used a different camera to the one listed in the original post as it had better reviews and is higher resolution: http://amzn.to/2ohHDMd  You get a different overlay (see below).
It's very compact and honestly looks like a factory-fit camera. I used black silicone sealant to fix the camera - rather than the back-nut as I didn't want to take too much trim off.  You only need to remove the top (brake light) trim, left trim (when looking at the open boot lid) and then partially unclip the main lower trim from the left hand side. Once you've drilled the hole in the blank area (aim for slightly below centre) you can then poke a stick or pencil through - to see where the wires will come out behind the trim.   I used T-Tap connectors from eBay to avoid soldering anything to the car's wiring. It was a little bit of a pain at these only really work with large gauge wires so I had to solder slightly fatter wire on to the ends of the camera's own cables to get a good connection.
Nick
Offline cliveastro
« Reply #16 on: May 02, 2017, 05:04:06 PM »
Hi
I want to fit a camera on 2015 mazda 3 sel nav hatchback and I wondered if you have any photos of your installation.
Have bought all the bits and set my DC to DC converter to 12v output.
I just want to be sure before I proceed,
Offline gravy258
« Reply #17 on: May 23, 2017, 05:05:44 PM »
I fitted the camera on my hatch a few days ago, all straightforward as described.
The four wires for the car are on the larger connector, not the top wire but the four below it facing you.
I set the voltage convertor with a chopped off USB cable, came out nicely at 6volts. (It was at 26volts output). A old phone charger would also do the job.
Started the car worked straight away. Well worth doing for safe reversing
I used the camera in Nickg's post
Offline newway
« Reply #18 on: December 03, 2017, 02:16:03 PM »
Parts list (other parts are available it's up to you what you use.)
Camera
http://www.amazon.co.uk/dp/B00RMKGMTO/ref=pe_385721_37986871_TE_item
Connecting cable
http://www.amazon.co.uk/dp/B013HTXDKO/ref=pe_385721_37038051_TE_3p_dp_1
Step-up Voltage Converter
http://www.ebay.co.uk/itm/HOT-DC-DC-ADJUSTABLE-STEP-UP-BOOST-POWER-CONVERTER-MODULE-XL6009-REPLACE-LM2577-/271837380870?hash=item3f4ac54106
Hello gknight9,
First of all thank you for your detailed instruction! I have the same 2014 3 fastback and tried to install a reserver camera myself. However I did not succeed :(
My step-up converter is different from yours, mine has a tiny LED indicator, if there is power coming from the 'IN', the led would lit up, even if the 'OUT' is not connected to anything. So I'd imagine when I connect the PCB connector to my car, restart my info-tainment and put into reverse, this LED should come on as well. But it did not, which seems to indicate that there is no power (5V) coming from my car. This is true whether I fully start my engine, or just start the battery with the engine button (2 presses)
Part from restarting the info-tainment and put in reverse, is there any steps I missed?
You said you don't need to start the engine, but do you only press the engine button once or twice?
Thank you very much!
Offline newway
« Reply #19 on: December 04, 2017, 09:41:57 PM »
【UPDATE】
I've finally make the reverse camera working. So here I would like to share my observations and hope it will help someone in the future who ran into similar problems.
My reverse camera and cables are brought from a different brand/vendor:
But the number of cables, the way they connected, are all identical to OP's settings. So at first I thought this is going to be a piece of cake! I can be so wrong...
My step-up converter:
Availabe at https://www.aliexpress.com/item/Free-shipping-1PCS-DC-DC-power-supply-module-boost-module-step-up-voltage-converter-Voltage-regulator/32677411593.html?spm=a2g0s.9042311.0.0.59TAA9
has a small LED indicator, if you connect the 'IN' side and feed power (e.g. 5V), the LED will light up, regardless on whether the 'OUT' side is connected (This turns out to be very helpful to my debug later on).
When I follow OP's steps to connect the black and red wires to the 'OUT', and keep the IN powered via a 5V power adaptor, the LED suddently turned off, when I loosen either the black OR red wire, it turns back on. This indicates a short-curcuit.
I spend a long time going back and forth on OP's post to see if I have missed anyting, until finally I use a multimeter to test the "power B" connector: there is continuity between positive(+) and negative (-) plates, meaning effectively there is only 1 wire inside the "power B" wiring, which is very strange. When I test the camera side (power A) and it is normal.
So in the end I have to do the following differently from OP's post:
1. cut the power B cable, reveal the black(-) and red(+) wires, soulder the red to the OUT+, black to OUT -
2. OP said to ignore 'the other wire' from Video B, but I have to soulder the 'other wire' to
   'IN -' along with the other black wires from the USB PCI
Other tips:
I use my TV to test my wiring and camera, using the composite Y video connector.
There is quite large gap between the USB PCI connector and the car's white connector, many times when I connect them I was only pushing the PCI connector below the pins.
It took me longer but I am glad it worked.
« Last Edit: December 04, 2017, 09:43:36 PM by newway »
« Reply #20 on: December 04, 2017, 09:46:13 PM »
Well done. Appreciate your update. I'm sure it will be useful to others (like me ) contemplating fitting a camera.
Offline gknight9
« Reply #21 on: December 06, 2017, 04:07:23 PM »
newway - Sorry I missed your post, congratulations on getting it working.
Offline paulm94
« Reply #23 on: February 13, 2018, 11:32:26 PM »
Removing one of your number plate lights could get you an MOT fail and possible police attention. Tapping in to Mazda electrics could also invalidate your warranty. The fun and games I'm having with Chinese DashCams makes me wary of connecting anything similarly sourced to anything other than a fused supply.
Offline paulm94
« Reply #24 on: February 14, 2018, 08:48:43 AM »
Thanks for reply I know I’m a mot tester myself but if you take a second look it come with the number plate lens cover all you do is fit bulb holder to the new lens so no mot issues it all comes as one piece and I just think £200 the camera alone is scandalous just because it’s 6v and not 12v you still need to buy the loom to fit it which is another £40 that’s cost to me
Just the camera and loom is another £40
« Reply #25 on: February 14, 2018, 08:52:00 AM »
Offline gknight9
« Reply #26 on: February 14, 2018, 10:58:42 AM »
Over 2 years since my original post, and my reversing cam is still working perfectly. Car has been through main dealer servicing and 1st MOT with out any problems or comments.
Offline paulm94
« Reply #27 on: February 14, 2018, 08:11:12 PM »
I’ll say this just one more time you are not removing the number plate light the camera is built into a number plate lens where the bulb is fitted so it still works but cameras is attached to lens did anyone actually see pics in link do not a mot failure
« Reply #28 on: February 14, 2018, 09:18:28 PM »
paulm94
I stopped at "Replace one of......".
You realise that by exposing yourself as an MOT tester, you'll get all the MOT questions now.
Offline paulm94
« Reply #29 on: February 15, 2018, 12:58:47 PM »
paulm94
 :D I better not say I'm a Mazda tech then as well  :-X
