Author Topic: Hendy Bodyshop - How many attempts does it take?  (Read 10780 times)
Offline Rob_Quads
« on: August 28, 2012, 09:02:53 PM »
We had the unfortunately situation to need to have our virtually new Mazda 3 repaired after an addicent in which it sustained some quite bad damage
When we got the car we were told all about the Mazda Accident Aftercare and so thought this would be the time to put it into action. Our insurer wanted to use an unknown local bodyshop but we let Mazda Accident Aftercare handle the issue and the car was transported the next day to Hendy Bodyshop in Segensworth (off to a good start). We expected that as this was going to a Mazda Approved that used Mazda parts etc the car would come back looking like new.
Within a few days we were told the damage and that the job had been approved so they had started work.  (again - all good)
Attempt 1
The car was then delivered back approx 1 month later. It was delivered to my wifes work address but unfrotunately it was raining so she could not perform a full inspection.  That evening it dried up and then when I got home I had a good look over it.
What can I say - A fairly poor job. It looked like the job bad been rushed and corners cut. So what was wrong.
Overall the colour match was very poor. This could be most seen on the rear door shuts where they had obviously taped up just inside the lip, sprayed the new (wrong colour) and then removed the tap. This left a really hash line and towards the top when removing the tape lifted some of the paint. This left a very rough proud section. How this could get through Quality Control is beyond belief.
Unfortunately Photos don't really justify how bad it looked in real life
This line went all the way the way from below the rear window to the front of the back door.
After noticing this we went on to see a number of things - many just careless such as where they had not properly removed trim pieces and then paint had got onto them and dried.
More tape marks on the edge of the bonnet - rough to touch so again no ideas how it got through "Quality Control"
We also noticed some other areas that had not been fully painted like the bottom front lip of the rear door, there were paint finger marks on the rubber trim.
Just as we thought we had seen everything a quick check on the arch then highlighted further sloppy work. Here you can see where not enough paint has been put down (the bluey looking line just in from the lip)
Then below this they had obviously sprayed some sort of back under-seal on the inner arch but not tapped off the painted panels resulting in splatter marks all over the paintwork
In all a list of 8 areas were highlighted that needing fixing. When we mentioned that we were not happy Hendy were good at sending out a replacement car and picking up the Mazda again
Attempt 2
Just under a week after having the car picked up to rectify the issues we went to pickup the car. We decided it was best to go to the bodyshop so that if we were not happy we could just leave it there...just as well. The day before delivery was spent waiting as the car was "waiting to be cleaned"
Overall it looked good at a distance again but when you went close there were some things still not right.
On the rear door shuts they had done a good job of sanding down the proud paint and blending in the colour so there was no noticable line BUT they they stopped at the back bottom corner of the shut even through it was obvious there was a clear line all along the bottom of the door shut. I just could not understand how they could not have seen this.
I also noticed more tape marks just under the rear small window, along with along the top of the window where lots of paint had been put down it caused a join between the painted panel and the glass (which will be fun to try and fix). Some more very small tape marks were found where they had not fully taped off the rear bumper.
One last bit was not done. The bottom lip of the door had still not been done "I was not sure which bit that was" why they didn't just pick up the phone and ask I have no idea.
It was obvious they had done quite a bit of colour sanding as there was compound marks all over the rear. The car had certainly not been cleaned very well. The inside of the rear door was covered in sanding dust.
So once again the car was left and we took away the loan car again. The following day we were planning to drive to Liverpool to spend the long weekend there. Via email we made sure that the bodyshop knew this and we needed the car by 12 if it was going to be done that day. We did clarify we would rather it done properly than rushed for the deadline. We were told that we would be told by around 11 whether it would get done in time..........you guessed it nothing till 1:30 to then say the car is ready!.  As there was not enough time to collect the car we put the 500 mile trip to Liverpool on the loan car.
Attempt 3
Thank-fully it was a dry day when we went to pick the car up. They had fixed the major issues we had pointed out but had not bothered with some of the others such as the paint all around the door sill piece, also where there was tape marks on the bumper where they had not taped it up correctly.
I also noticed that they had used way too much laquer when doing the door shuts as you could feel the run but it had got to the point we just wanted the car back. It was good to know that the car had been valeted.....well if thats what they call valet it only matches up to the quality of workshmanship we have seen so far
Couple of pictures to give you an idea of thier 'valet'
Just a little bit of sanding dust
Done
So - Maybe we should just have let Admiral sort it for us as the Mazda approved Hendy bodyshop experience was very poor, very sloppy work. They obviously had the skill to do the job properly if they wanted but they were cutting too many corners. Something I would not expect for expensive insurance job.
So far its been a pretty poor experience of the Hendy Group company after the poor state the car was delivered in when we bought it, now the bodyshop. Will we give thier service dept a go - lets wait and see.
« Last Edit: March 28, 2013, 11:02:20 PM by Rob_Quads »
Re: Hendy Bodyshop – How many attempts does it take??
« Reply #1 on: August 28, 2012, 09:29:25 PM »
hello mate, sorry to hear about your troubles. I unfortunately went the same route you did, 2 years ago when my Mazda was hit by a lorry. What a mistake that was! always get the job done by your own insurance company. Having it done by 3rd party claims management companies are more hassle than its worth. I for sure learnt my lesson the hard way. Now I always get the job done by my insurance company even if I'm not at fault.
Hope you can fix the little left over issues.
Offline Gavin
« Reply #2 on: August 28, 2012, 10:34:43 PM »
awe man, what a nightmare. i bet it gutting for you as well on a car so new aswell. what shocking workmanship. they shouldnt be alowed to trade.
Offline Rob_Quads
« Reply #3 on: September 04, 2012, 09:07:31 AM »
Delete Post
« Last Edit: March 23, 2013, 09:47:05 PM by Rob_Quads »
Offline Rich196
« Reply #4 on: September 04, 2012, 10:27:58 AM »
I dont know what kind of that money the damage cost to repair. If the car was less than 6 months old I would have been tempted to get them replace it to be honest. I hate body shops!!!
Offline Rob_Quads
« Reply #5 on: September 04, 2012, 07:11:12 PM »
As much as I would liked to have got them to replace the car you have no grounds for a complete replacement. Worse case they would just write the car off. The damage was around £4.5K worth.
Today found further a finger print, cloth fibre under the lacquer in the door shut, dust in the lacquer on the handle and where they have not tapped off the petrol filler lacquer OVER dirt! which is now sealed
« Last Edit: March 28, 2013, 11:03:03 PM by Rob_Quads »
Offline gazpot0111645
« Reply #6 on: September 04, 2012, 08:50:38 PM »
Thats terrible i have to say. You always expect the slightest of problems but not like this. Before i got my 2nd mazda 3, my VW golf mk5 was hit. I have to say the job done on mine was pretty good. I feel for you.
Carbon Grey 2007 (07) Mazda 3 2.0D Sport 5 Door hatchback.
Offline billey01
« Reply #7 on: September 04, 2012, 09:01:46 PM »
OMG i feel for you.
Offline Rich196
« Reply #8 on: September 05, 2012, 12:34:16 PM »
I have had member of my family insist on cars 6 months or less old being replace when there has been alot of damage done. They have never had a problem with it. Repairs were normally costing around a 1/3 of the cars value.
I would keep going back until its right, and maybe speak to mazda Uk about it. its awful service!!!
