Author Topic: Driver electric window controls not working  (Read 10471 times)
Offline Three
« on: April 18, 2012, 12:03:45 AM »
The battery in my car had been flat for a while.  The car was jump started and now runs on a battery charger every few weeks.
For some reason, the driver electric window controls for the passenger windows no longer work?
Only the driver electric window control and the individual window controls (for each passenger) work.
Offline sk4tec
Re: Driver electric window controls not working
« Reply #1 on: April 18, 2012, 12:09:25 AM »
Try dropping each window by its switch and then putting it up and holding the switch up for 2 seconds.
1998 Peugeot 306 XSi 16v
1999 VW Passat 1.8 Sport
2002 Golf Mk IV GT TDi 150
« Reply #2 on: April 18, 2012, 01:30:20 AM »
As stated above, read this it explains it very well.
Window thing is simple... Apparently its in our book.. but hey, I am a man and don't read such things..
When the battery is removed, the windows need to be reprogrammed so the auto closure knows when to stop..
Just goto each of the other windows, lower it a couple of inches, then raise it back up to close again, keep your finger pulling the switch up when it has stopped for maybe 5-10 secs, you will hear a very quiet click. This click means it has been set at the close position.
Do this on each of the windows and then try your drivers door again and all should be good.
Weird thing was, this didn't happen when i disconnected the battery.. Go figure..
Hope that makes it work!   :)
It's often a good thing to check using the search function to see if your question has already been answered.
This forum has been running now for over 5 years and during that time has covered inumerable subjects. If anyone has an enquiry often times it will have already been the subject of a discussion.
Remember Search is your friend
Offline Three
« Reply #3 on: April 19, 2012, 03:15:02 PM »
I believe the auto-closure is only for the driver window not the other windows?
« Reply #4 on: April 19, 2012, 03:25:05 PM »
?? Have you tried the above procedure ?   It will solve your problem.
Offline Three
« Reply #5 on: June 05, 2012, 02:05:46 PM »
Just to report back, the above procedure worked.
Thanks to all!
Offline zoomzoomer
« Reply #6 on: June 05, 2012, 06:40:36 PM »
and for me too.
i had a problem with the rear passenger window not working with global closure,tried this and is now working fine.
i tried searching for problems with global window problems ::)
thanks.
Offline DaftDriver
« Reply #7 on: June 05, 2012, 10:01:47 PM »
You might get this problem a few times again until you get a new battery, I had the same problem. When a new battery was fitted it went away!
Done: Light smoke tint all round, Powder coated wheels in charcoal grey, LED number plate + side + interior lights + front fogs, Carbon look centre console, Black magic tree and Baby on Board sign.
