Author Topic: brake warning light  (Read 3224 times)
Offline lambretta1
  • new mazda 3 member in bristol
brake warning light
« on: February 14, 2021, 11:14:25 AM »
does anybody know where the obd11 port is on mazda 3  ts 1.6 diesel  is  ? thanks in advance
Re: brake warning light
« Reply #1 on: February 14, 2021, 11:18:07 AM »
Should be in the top of the cubby beside your right knee (assuming right hand drive).
Offline lambretta1
« Reply #2 on: February 14, 2021, 11:31:41 AM »
thanks steve yes it is a right hand drive  , whats a cubby ?
Offline lambretta1
« Reply #3 on: February 14, 2021, 11:33:03 AM »
does the brake warning light indicate brake pads low ?
« Reply #4 on: February 14, 2021, 11:39:31 AM »
Looks like a little storage shelf big enough for a set of keys, rectangular opening set in the dash to the right of and below the steering wheel. Should be a connector set into the top of it facing downwards. You can't see it from the drivers seat, if you're on your knees next to the car you'd see it.
Brake/ABS warning light is multifunction so if it's permanently on I'd read the codes which you assume you are trying to given your question.
Offline lambretta1
« Reply #5 on: February 14, 2021, 02:17:11 PM »
ok thanks for your advice  mate .
