Hi Engineer Andy,
Thanks for the pointers and advice, i think the same as you do, the previous ower was supposed to be an engineer and performed regular 'home' services but i doubt that very much as when i changed the engine oil it was black and the gearbox oil was also black.
The car looks like it only did 2000 miles a year for the past few years, overall the internal upholstery is in very good condition, the outer bodywork is in ok condition as there are lots of those little scratches from the previous owner holding the keys on their had while getting in and out of the car.
The plugs are standard NGK BKR5E-11 , i'll be changing those to the recommended NGK BKR5EIX-11 as the history of the plugs is unknown.
I have a whine noise when the engine is running, which is quieter when the AC is turned on and louder when the AC is turned off , i'm guessing its worn AC clutch pully bearings
